Soviet tubes
hobo_nephew | 06.10.2011, 11:51 | |
| Гость | This might not be the right forum for this, but you guys helped me before so here goes; I'm planing to build my own guitar amp using 12AX7's and EL34's, and off course I want to use soviet tubes! So does anybody have some recommendations? I want a smooth sound and was thinking maybe Svetlana tubes? | Наверх | |
vint | 06.10.2011, 12:24 | |
| ID пользователя #2308 Зарегистрирован: 19.12.2010, 20:53 Местонахождение: Комрат, Молдова Сообщений: 2991
| EL34=6П3С soviet tube
Мнение большинства не всегда верно. Ни миллиард мух, ни два, ни три, ни даже больше... Не убедят меня, что дерьмо-это вкусно. | Наверх | |
GeorgeM | 06.10.2011, 14:05 | |
| 6н2п not a 12ax7 ! other pins, heater 6v only. sound is little bad. el34=6п27с. ...but 6п27с is mifology. bad idea.
if you want smooth sound - i recommended oktal 6н9с(6SL7) + 6п6с(6V6), or 6п7с, or г807("807"). Kenotron - 5ц4с(5Z4), 5ц4м(5Y3), 5ц3с(5U4G).
or use modern russian tubes "svetlana", "tung-sol", "electro-harmonics". 12ax7 + 6550(as my "15watt champ").
[ Редактирование 10.10.2011, 06:39 ]
Claydon | 06.10.2011, 17:50 | |
| I am sorry, but at me a question: what for to make the lamp amplifier on old Russian element base? After all besides radio tubes, the qualitative target transformer is still necessary to provide a correct operating mode of the terminal cascade. Whether to buy the inexpensive semi-conductor amplifier, for example, Ibanez-TBX15R is better?
GeorgeM | 07.10.2011, 04:01 | |
| tube is better sound.
transformer - its no problem, tvz-*, tesla, beag, modern - yerasov, audioinstrument, e.t.c, modern no russian - millions....
hobo_nephew what amp you need, se? pp?
-Putnik- | 07.10.2011, 10:09 | |
| ID пользователя #2458 Зарегистрирован: 07.03.2011, 17:40 Местонахождение: Днепропетровск - Макеевка Сообщений: 3580
| GeorgeM, can you share the pattern combo on 10 watts or less for use at home to the Soviet base and a 100% working. How many schemes - so many opinions. )))
Обменка [link] | Наверх | |
GeorgeM | 07.10.2011, 11:35 | |
| Their thousand. Since fender champ, аnd finishing higain monsters...
at example my combos: [link] - old schematics, modern element base 90% soviet. For exclusive soviet element base - schematics will differ it is not enough, literally in pair details.
[ Редактирование 07.10.2011, 11:41 ]
GeorgeM | 10.10.2011, 06:33 | |
| This 6П27С [link] - one of 5000
hobo_nephew | 10.10.2011, 09:33 | |
| Гость | Thanks for all your replies! Looks like I have some work to do checking out all those tubes! The amp design is my own so it might need some tweaking along the way. I uploaded the schematic here: Schematic Feel free comment about my design as well.
[ Редактирование 10.10.2011, 09:35 ] | Наверх | |
GeorgeM | 10.10.2011, 10:18 | |
| Interesting schematics, may be will too much hi frequency? I would increase С1,2,3, 10,11,12, decrease C14. For more vintage(50s-60s) sound may be applied "self-split" phase inverter. Or for more modern, equal sound - may be add negative feedback from output transformer.
R3 - may be 33k, as classic fenders ?
hobo_nephew | 10.10.2011, 18:43 | |
| Гость | I will definitely change those values if it makes the design more leveled. Do I add the phase inverter between preamp section and power tubes? And what exactly does it do tonewise? I do prefer a more vintage sound before modern | Наверх | |
GeorgeM | 10.10.2011, 20:18 | |
| hobo_nephew Цитата ...
I will definitely change those values if it makes the design more leveled. I didn't carry out calculation, but I think that so it will be better. Check is necessary.
If you interesting self-split, then look phase inverters from schemes "vermona regent30" and "fender princeton65(aa964)" - one triode and good old sound. And look this: [link] - self-splitter pushpull without separate phase inverter. bad for the hi-gain, fine for "chicago sound"
violet | 11.10.2011, 14:49 | |
Зарегистрирован: 31.05.2006, 16:17 Местонахождение: Berlin, DE Сообщений: 190
| I've built a couple of 5-watters using 6П14П tube for output section (equal to EL84, can be substituted without modifications). Preamp section can be built with 6Н2П of course, you just have to keep in mind that heaters difference. | Наверх | |
violet | 11.10.2011, 14:55 | |
| You may found the following schematics useful:
hobo_nephew | 12.10.2011, 12:18 | |
| Гость | Are there any good site with information on how to calculate capacitor values? To be honest I don't know how. First time ever trying to build an amp. The phase inverter I do understand how to implement, altho not sure about resistor values. You guys just made this build a lot more complex for me! But it will be a lot of fun Thanks for helping me out! | Наверх | |
violet | 14.10.2011, 12:15 | |
| hobo_nephew, maybe it's better to start with some prepared project from ax84.com site to focus on pinouts, soldering and overall safety | Наверх | |
hobo_nephew | 15.10.2011, 11:09 | |
| Гость | It would probably be the smart thing to do, but it's not how I do things I'd rather redo some things along the way and learn something while doing it! Can't be that hard can it?! | Наверх | |
violet | 28.10.2011, 21:41 | |
| It's ok while you don't touch bare wires, or charged capacitors Have you already built smth? | Наверх | |
hobo_nephew | 06.11.2011, 20:28 | |
| Гость | have been really busy so haven't had the time, but the schematic has been updated and I'm quite pleased with it. I have also received the transformers I ordered for the build. Will let you guys know when there is progress! | Наверх | |
GeorgeM | 06.11.2011, 21:24 | |
| hobo_nephew: mirror topic - [link] %-))
[ Редактирование 06.11.2011, 21:24 ]
