Doina Star 3
altro | 09.12.2019, 08:16 | |
| Гость | Hey, I've recently picked up this Doina and been trying to wire it up.
Correct me if I'm wrong, but my undestanding is that - Black wire is the guitar switch, White is the hot wire and the copper one is ground.
This is the wiring I tried using some alligators, and couldn't get any sound.
Here are some images.
Thanks! | Наверх | |
Gess | 09.12.2019, 16:26 | |
| good day I can be wrong, but in the photo the signal is white. black and copper-ground. Jack only mono, stereo not need I think other comrades will correct me if I wrong and God save the Qween )
Gess | 10.12.2019, 11:01 | |
| see it [link] [link]
lordbizarre | 05.06.2021, 15:26 | |
| ID пользователя #2427 Зарегистрирован: 22.02.2011, 16:44 Местонахождение: Brussel, Belgium Сообщений: 43
| there's only one and simple connection possible : on the pot one side is grounded ; the opposite side is the hot ( incoming signal ) and the middle is the variable and only connection that goes to the (mono)jack . The copper is usually jack-and circuit ground ! succes !!
"lordbizarre's electric guitar and amp museum" repair & expertise guitars and amps Belgium , ?pe [link] | Наверх | |
