Question about Formanta wiring
OveA
25.11.2017, 19:16 Просмотр для печати
ID пользователя #9227
Hi!
I´m restoring formanta guitar. One guy decided to solder it cooler and messed all up....Now i got everything back together and even fuzz is working... I drew red circle around my problem. Does capicators and resistors goes between hot and switch or from switch/hot point to grounding. I tried several ways, but non of versions seems right. I don´t have three bottom switches and trying to built temporary solution.
Thank you for answer!
OveA
26.11.2017, 09:14
Nevermind, i got it.
Yesterday i was tired and sleepy, today i used some logic and everything is working.
26.11.2017, 09:23
How do you fuzz? To play, say as Panther or King Crimson? Really? )))
26.11.2017, 09:56
Please note that the numbering of the parts of the wiring diagram does not correspond to the numbering of the parts on the circuit diagram.
Namely - on the wiring diagram the numbering of R13 and R15 needs to be interchanged.
The output signal is removed from R15.
Good luck!
OveA
26.11.2017, 10:32
Well fuzz is not something special but most important was to get it work
OveA
26.11.2017, 10:41
Good luck!
Yes, i figured that out. Problem was only with marked area but it was so simple mistake I woke up early morning and after one coffe i got it. Those tumbler switches are just for testing and little video, didn´t want to wake up neighboards.
[ Редактирование 26.11.2017, 10:42 ]
Категорически поддерживаю!
Георг с днюхой!
А что он натворил?
ну а как еще?
Нарушил правила что ли?
