former USSR transistors
lordbizarre | 18.04.2011, 12:08 | |
ID пользователя #2427Зарегистрирован: 22.02.2011, 16:44 Местонахождение: Brussel, Belgium Сообщений: 43 | well , don't know if I'm at the right place but I take my chances ! so here she goes : I have a former USSR effect ( called Effect Bay-Bay , thus Effect Vau-Vau or Wah-Wah , build at Krasnoseljskaja street) and I'm getting the schematic out of the hardware . In this effect they used some realy old fashioned MP41A germanium transistors ( although here dated 01.81 they're already to be found in a 1968 transistor receiver) , with the battery positive to the ground.Others transistors are KT203B ( or KT203V) .From both I have found some data sheets ,those aren't the problem , the other are ! The're two with only "G"(in cyrillic) marked on them and another with KD302BM ( or KD302VM) I wonder what that last electronic device is , because it's marked on the pcb with cyrilic E , I and K ,not E B K as usual transistors .The "G" marked are transistors due to E,B,K markings on the pcb.Those "G" 's can also be found in Formanta , Borisov Solo II & Bass I . Do you know something about them ( those "G" and KD302BM ), have you some data about those ussr transistors ...or if not :do you know someone who has ? thanks !
"lordbizarre's electric guitar and amp museum" repair & expertise guitars and amps Belgium , ?pe [link] | Наверх | |
Fizzzik | 18.04.2011, 16:36 | |
| Гость | Hi, sorry for my english.
Are you sure that кд203 is a transistor? So usually denoted by a diode.
кт - Кремневый Транзистор (silicon transistor) кд - Кремневый Диод (silicon diode)
for example: [link] | Наверх | |
Zeddy | 18.04.2011, 18:31 | |
| ID пользователя #1341 Зарегистрирован: 18.09.2009, 18:09 Местонахождение: Наро-Фоминск Сообщений: 4704
| Hi, lordbizarre! KD302BM - this wrong designation. Correct designation - КП302ВМ ! The metall-oxide-semiconductor field effect transistor!
Analogs of components: МП41А - 2SB175, AC542, ОС75, 2N2428, 2N369, 2SB120, 2SB175 КТ203В - 2N2276, 2N2277, 2N2372, 2N2373
And at last, КП302В - 2N3972, MFE2098(but other body)
It so easy... Good luck!
[ Редактирование 18.04.2011, 19:13 ]
Обмен - [link] Менялка педалек
Заштатная сволочь. | Наверх | |
lordbizarre | 18.04.2011, 21:03 | |
| ID пользователя #2427 Зарегистрирован: 22.02.2011, 16:44 Местонахождение: Brussel, Belgium Сообщений: 43
| yes it's that effect ! thanks very much for the info , my schematic is complete now ( and the same as in the link ) !
PIT666 | 18.04.2011, 22:06 | |
| Here is a full-size photo of the schematic diagram [link]
