"plug & play " add-on pu's for acoustic guitars
lordbizarre
24.10.2013, 13:58 Просмотр для печати
ID пользователя #2427
Местонахождение: Brussel, Belgium
Hi !
I've two acoustic guitars with an add-on pu-guard "plug & play"(matter of speaking). One is a Izyaslav 332-y (right)and the other(left) a Zhitomir acoustic ( pickguard doesn't fit well but what the heck...),so both from Ukraine.On the back of the pickguard there's a "L" and an (obvious-)CCCp mark.Can someone point me out the manufacturer and/or the modelname/number from this pickguard.
...and if possible : the modelnumber/name for the Zithomir acoustic ?
yhx !!
"lordbizarre's electric guitar and amp museum"
repair & expertise guitars and amps
Belgium , ?pe
Vovka
24.10.2013, 14:15
lordbizarre Цитата ...
Hi !
yhx !!
Привет!
У меня два акустических гитар с дополнения пу гвардии «подключите & играть "(вопрос о выступая). Один является Изяслав 332-y (справа) и другие(слева) Житомир акустические (pickguard не подходит хорошо, но то, что щеколда...), так как из Ukraine.On задней части pickguard там «L» и Марк CCCp (очевидно-).Может кто-нибудь мне точку производителя и/или modelname/номер от этого pickguard.
.. .and если возможно: имя modelnumber для акустической Zithomir?
yhx!!
Баранкин
24.10.2013, 14:29
ID пользователя #2776
Hi! In that time "Zhitomir acoustic guitar" in fact, was a brand of guitar. It has an article, but it means nothing, because Zhitomir factory produced only two types of guitars - one of those you have on your photo, and the second is [link]
However, pickguard with pickups was made in Leningrad - which now called Saint-Peterburg. The factory, which produced them, called MAGNETON. Description of this device was made by director of this forum, called YA-HA. Link on description [link]
I tryed to translate it in English for you:
"Device consists of two singles and a control unit. Defeat scheme is not quite clear: left stick - the master volume, the average - the general tone and the right - the signal neck pickup, mixed with the bridge pickup. Potentiometer knobs are completely similar in form to those that were placed on the guitar kit MARIA). Connector - Soviet little jack, having a diameter slightly less than usual. The device is mounted on an acoustic guitar in the socket with spring tabs upper sensor and two tiny screws on the mare. The sound of the resulting "electrified acoustic guitar" on the clean channel - predictably flat and featureless, but on reloading is quite possible to squeeze something evil and dirty, like the early "STOOGES"."
