Японская Eterna
Dimma | 06.02.2020, 14:50 | |
ID пользователя #292Зарегистрирован: 26.10.2007, 01:03 Местонахождение: Львов Сообщений: 2139 | Попалась мне на просторах eBay вот такая забавная японская версия Этерны, от фирмы Maya [link] [link] Ссылка на объявление: [link] | Наверх | |
Cdur | 06.02.2020, 15:08 | |
| ID пользователя #10143 Зарегистрирован: 28.05.2019, 15:11 Местонахождение: Санкт-Петербург Сообщений: 4521
| Да, была такая фирма Maya в г.Кобе, читал про нее и аффилированную с ней компанию El Maya, которая делала копии Фендеров лучше, чем материнская фирма Maya - они по качеству упоминаются как равные оригинальным Фендерам:
[link] “Maya” was a brand named used by a Japanese Trading Company from Kobe called Rokkoman. [Source: EZ Folk ] Established 1970. to ? 1995.
The guitars were marketed in the UK by Stentor [Source: Guitar site]
They were made in Kobe Japan by the Maya Guitar Co. The plant where they were manufactured was destroyed in the 1990s by an earthquake. They made high quality knock offs of Gibson and Fender Guitars. [Source: Derkeiler]
They built medium quality guitars . There was an affiliate company ElMaya whose Fender copies were better made than Maya and equal to what Fender was producing. [Source: Derkeiler] Acoustic guitars with the brand are also around.
[link] Maya Guitar Company Located in Kobe, Japan, this manufacturer made the famous Maya brand guitar. Maya guitars were in production from 1970-1980. It's been suggested that Maya may have been responsible for the Aztec badge. You'll notice that Maya has been attributed to a company known as Tahara. At this point I do not know if Maya assisted in production or if Tahara produced some Maya guitars as a subcontractor. Maya and El Maya badges have also been attributed to Chushin Gakki. More research is needed to clarify this point.
leopold | 06.02.2020, 15:22 | |
| ID пользователя #2616 Зарегистрирован: 19.06.2011, 16:49 Местонахождение: Котельнич, Кировская обл. Сообщений: 2417
| Анкера не вижу.
Cdur | 06.02.2020, 15:28 | |
| Интересно, что крышки звукоснимателей на этой гитаре El Maya из объявления очень похоже на те, что видны на гитарах JVC - см. [link], [link] и [link].
В последних 2-х ссылках на фото гитары JVC SG-18 есть надпись на голове грифа «EVERTONE Electric Guitar Works Kobe Japan», т.е. гитарного производителя из того же г.Кобе - однако такая гитарная фирма EVERTONE из г.Кобе нигде больше не упоминается...
PRM | 28.02.2020, 03:21 | |
| ID пользователя #10834 Зарегистрирован: 18.02.2020, 23:34 Местонахождение: Москва Сообщений: 144
| leopold Цитата ...
Анкера не вижу.
Анкера там может и не быть, японцы в 70-х, от своей нищеты и ущербности чудили не по детски, я видел дорогие Ибанезы из картона, фанерные инструменты это вообще лицо Японии 70-х | Наверх | |
roman66 | 28.02.2020, 06:13 | |
| Давно интересуюсь джапаном. Ждёт своей очереди на реставрацию Кавай арктоп. Ямато вообще, по косточкам собрал. Они может ущербно-хванерные но играбельные. А по поводу эстетеки дадут фору многим немцам. | Наверх | |
