RIGA Viola Compressor - Mod for Less Distortion
DIYGuitarist
24.06.2024, 14:14 Просмотр для печати
ID пользователя #20174
Местонахождение: Nevada USA
In this post, about 10th reply from the top, grizzlytone described a way to reduce the distortion on the Viola Compressor.
https://sovietguitars.com/e107_plugins/forum/forum_viewtopic.php?103421.0
I just wanted to say that this does indeed work. I added a 4.3 zener diode to mine over the weekend and the pedal is so much more usable now.
You can also see it on the oscilloscope! Can hear it more than you can see it in these pics. Top is without the zener diode, bottom is with. Only get distortion
with the level control at maximum but the level control is now usable to about 90% maximum level. When it does distort, only the bottom half of the sine wave hard clips.
It does this with or without that zener diode, is a little less severe with the diode installed.
Thanks grizzlytone!
24.06.2024, 17:18
DIYGuitarist Цитата ...
Sorry, the link presented above does not work. Probably, it was meant the post by grizzlytone dated 14.08.2011, 13:00 at the page [link] (which is tge 10th one from the top, indeed).
[ Редактирование 24.06.2024, 17:19 ]
DIYGuitarist
24.06.2024, 17:50
[/quote1719251415]
Yes that is the post I refer to. The quote function isn't working correctly for me for some reason.
[ Редактирование 24.06.2024, 17:51 ]
С Днём рождения, Юрий!
